- Sep 18, 2003
- Michigan State Uni
its been a yr since i had my comp in my sig and i havent turned it on since may..iv been using another computer because i didnt feel like setting mine up.
anyway i turn it on and now after post screen itll beep and say
new cpu installed! please enter setup for configuration
f1 setup
f2 defauts
so i do setup..not sure what i needed to change but boot to windows..i restart to test it again and again itll say new cpu installed etc.
i had a zalman cu7000a on it and then i tried with the stock hs and it still says the same thing.
and now odly enough at ranom boots windows will crash reboot itself..go to the message and then after hitting f2(just to get past the screen) windows will say it recovered from a critical error.
but the main concern is why the cpu would keep registering as a new cpu every boot.
ill try and expand after work today.
thanks for reading
f1 setup
f2 defauts
thanks for reading
