- May 27, 2002
- Ohio
PC specs are in sig.
Basically, I've been on this current installation of XP for way to long, and it's starting to show. Getting slow-downs, Driver problems which is causing video problems...Etc.
I bought Vista a while back, way before SP1 came out, but quickly put XP back on, due to lack of driver support for a majority of products that i owned.
Well, I'm about to reinstall Vista again, Since i figure that if I'm going to do a clean install, I might as well use vista, and be able to use DX10 on my 2 8800's.
The problem is, I only have 2 gigs of ram. Not to get into the details, but I'm basically STUCK with only 2 gigs of ram, unless my motherboard will suddenly work correctly with all 4 dimms being used.
So how well will vista run? I plan to game on this machine. I use Dual Monitors, and will be running BOINC 24/7. Will it run fine, or should i keep XP until i do a PC upgrade, where i will be having at least 4 gigs? ( which an upgrade may be MONTHS away. )
