- Jan 3, 2005
- Guildford, England
Hi,
I have two windows 7 queries that have been plaguing me for ages now.
1. I cannot put my PC to sleep, every time I do it gets immediately woken up. I have checked the event logs and a USB Hub is responsible. However I have already marked all my usb connections as not being able to power the PC on.
I have tried resetting all my power cfg to default as well to no avail.
I dont know how to be able to narrow it down from the generic usb hub, to find what is waking the PC up though.
Idealy I want to be able to put my PC to sleep instead of turning it off.
2. I have my PC plugged in via HDMI to my reciever, then another HDMI from there to the TV. This works great, however if I am listening to music I turn the TV off and control the music with an app on my phone. The problem is that it will occasionally disconnect and reconnect causing ~2-3 second break in the music. As if it is trying to find the display. This never happens while the TV is on. Any way of stopping windows 7 doing this?
(on a side note as well just incase anyone has any ideas, I use mediaportal as a front end, mediaportal doesnt cope well with changes of resolution and when I turn the amp off, the PC changes its resolution away from 1080p, when I turn it back on the resolution is back at 1080p, however mediaportal stays at the smaller size, to fix this I then need to alt+enter, to exit full screen mode and then do it again to go back to full screen. I am hoping there is a way to prevent windows from changing the resolution when the display is disconnected)
Thanks in advance
Thanks in advance
