Hoot said:It's unlocked, so you can also raise or lower the multiplier. Keep us abreast as you work through it's limitations. A lot of people are looking at the 2800 recently.
Hoot
c627627 said:Sorry masitti, extensive tests were done by other members of this forum, looks like we won't be able to.
Good all Hoot sliced up a working locked Barton just to confirm this.
Core info 2500+:
AXDA 2500 DKV4D Z359127250156
AQZFA 0335 MPMW (tm)(c) 1999 AMD
"Update: Retail and bought in The Netherlands."
And it's LOCKED!!!!
I can't change the MP on an Asus A7N8X rev 1.04.....i've tried everything i know. Flashed bios 1004 till 1007 and none of them could change the MP.
Do i have the lowest week thats locked?
c627627 said:Yeah, I was summarizing what he was saying just so we're clear, I knew there were markings with letters on unlocked Bartons, but what's this with the AMD logo he's saying?
zusatz ,
mir viel gerade ein hatte mal nen AQXEA aus 11 2003 und der war ungelockt
also denke ich gab es früher generell keine gelockten barton´s .
jetzt frage ich mich, was soll das von AMD, AQXDA war so ziemlich das erste stepping
vom Barton, datieren die die dinger jetzt schon zurück.
aber eins ist mir aufgefallen und zwar gehts um den kleinen schwarzen aufkleber auf dem das stepping etc. steht , bei allen gelockten war es ein neuer mit dem AMD symbol auf dem aufkleber und innerhalb der seriennumer sind buchstaben, was bei den ungelockten auch nicht war .
addendum,
just remember I once owned an AQXEA from week 11 in 2003 which was unlocked, so I gather before there weren't any locked Bartons
Now I wonder what's AMD doing, for AQXDA was really almost the first stepping of Bartons. Are they now even predating their babies?
But one thing was conspicuous, namely the little black sticker with stepping and all. Locked ones featured a new badge displaying the AMD symbol and further there were letters within the serial - something the unlocked Bartons hadn't either.
Ich habe eben genau den selben bekommen. Der lässt sich weder über multi noch über FSB hochtakten
Die genaue bezeichnung ist AQXDA 0315 MPM
Habe das ASROCK k7S8X. Multiplikator änderungen werden einfach ignoriert und wenn ich FSB erhöhe sagt mir das bios:" Ihr CPU mag sie nicht, ändern sie die einstellungen oder ich setze sie automatisch zurück"
Wenn ich per jumper auf FSB 200 stelle kackt er ab, kurz nachdem windows geladen hat.
also ich will damit sagen das es jetzt schon barton´s aus der 15KW gibt die anscheinend
mit dem neuen multilock versehen sind , was ich anfangs nicht glauben konnte und wollte
und was mir an der ganzen sache komisch vorkommt ist, obwohl die cpu aus der 15KW ist und eigendlich das typenschild noch im alten designe sein sollte , ist auf dieser cpu schon eins im neuen designe mit dem AMD symbol , finde ich auf jeden fall komisch oder und wenn jemand in einem PC-Shop ähnliche cpu´s findet die aus einer KW stammen die eigendlich ungelokt sein sollen welche auch das neue typenschild mit dem AMD-Symbol auf dem aufkleber haben , sollte er vorsichtig sein.
NapalmV5 said:Just got my mobile 2500 barton from newegg. Unlocked, 0335, boots at 2500 (200x12.5 @ 1.7v), on abit kr7a-133r. Gotta do the volt mod cause 1.7v is the max. Also, i gotta look for the wire trick to get higher multis.
