- Oct 30, 2010
- Seattle, WA
Hey all, so the 230mm fan on the side of my Thermaltake Armor + went out so I bought a BitFenix Spectre Pro BFF-LPRO-23030B-RP 230mm Blue LED Case Fan. The fit is perfect and it looks great and seems to be working fine.
My question is - do I use the 4 screws to secure the mount from the outside or should i use the the stretchy rubber rivets instead? I haven't noticed anything wrong so far but I want to make I install it correctly. And of course there were no instructions in the box
Thanks all!
Thanks all!
