- Dec 25, 2004
Last monitor I bought for my 3 monitor setup was a "ASUS MG279Q Black 27" 144 Hz 4ms (GTG) WQHD Widescreen 2560 x 1440 LED IPS Panel, Adaptive-Sync (Free-Sync)". Doesn't look like they are making that version anymore. The other two monitors I have are 1080P, and 22" and 24".
The old monitor I have for my garage system died, so I replaced it with one of the 1080P montitors and now I need to replace it.
The different resolution monitors are slightly annoying when the mouse gets stuck in the center one trying to go to the edge. So I was thinking getting another 27" 2K monitor would be a good choice. But I'm wondering with 3070Ti or maybe 3080Ti cards if I should get a 4K one instead, and just deal with the mouse pointer issue.
Is the better resolution worth it, or not a major consideration?
Thanks!
Thanks!
