- Dec 10, 2002
- Hillsboro, OR
not sure if this is OS or here, but it is regarding game performance. does xp have any benefits over games on 2kpro?
thanks
thanks
Yeah...regrettably, the motto of Microsoft's game division in re operating system support is "---- you, what are you going to do about it?"mdameron said:...Which directly relate to gaming performance... As you can see, it's very arguable either way. If you have XP, leave it on there. You'd be pretty ****ed to see how little increase you'd get, if at all. Plus, there are new games coming out that won't work on anything older than XP. A bit Nazi, but that's the way this ol' world works.
doublejack said:My opinion is there is no perceivable difference from a performance viewpoint between XP and 2k. There is a measurable difference between the two which benchmarks reveal, but it's such a small gap that there's no impact to gaming. For example, if Doom3 is barely playable at 1024x768 with medium detail on XP, switching to 2k on the same hardware is not going to improve the situation. It won't jump your average fps from 25 to 30, and it certainly won't allow increasing the resolution or detail if playability is borderline on XP.
In all other categories XP is either better than or equal to 2k, so lacking any real performance gap I think it's logical to conclude that XP is the preferred OS. Is it worth upgrading from 2k to XP? Probably not at this point, but it depends on the individual's needs. XP has some nice security features for the computer novice so it may be a wise move for them. On the other hand, if you have XP installed already then it makes absolutely no sense to revert back to 2k. Similarly, if you didn't have either and had to pick one to buy, XP is the clear choice.
