- Dec 25, 2004
Ok, I've got the system in my signature. I just got in my second 8800GTS and I figured I would test it out. Swapped it out for the current one and ran 3DMark06 on it. No problem, other than I forgot to reset the defaults on bootup for RivaTuner. It locked up. Ok, probably not as good of an overclocker, but I'll deal. Get them set properly for defaults and run again. Almost identical score to what I got for my first card.
All going according to plan so far.
Put the original back in as well, plug on the SLI connector and turn it on in the bios.
Enable SLI.
Run 3DMark06. Whoo-hoo, a 15 FPS gain at the start...but wait a minute! My system just shut down! Right when the FPS would drop from heavier load.
Ok. Reboot and do a clean reboot. Run again.
Crashes in the exact same spot.
Reboot and clean reboot, and turn the settings down to 450/700. Run 3DMark06 again. Turns off again.
CRUD!!!
Ok, I enabled hardware monitoring on the last run and it appears that the temp was actually going down right before the crash. Ok, not an overheating issue. Temps were 52C and 47C before the crash.
Any idea what could be wrong? I can get another PSU if it isn't holding up.
I've got all 3 power points on the motherboard connected and the PCI-E 6pin plugs connected to the cards!
Just to double check, I pull the 2nd card out and run 3DMark06 again. No crash with a single card.
HELP!!
Enable SLI.
CRUD!!!
HELP!!
