- Dec 25, 2004
I mentioned this in the 5902 thread, but I'm pointing this out in a different thread because nobody seemed to pick up on it.
I've got 2 GTX 295 cards in my main Vista 64 computer. So far, since I only have 1 monitor I can use at the moment, I can only run 3 GPU2 clients.
I turned on -advmethods in my clients and got 3 5902s in short order. However, 1 of the clients is producing almost twice as much PPD as the other 2. It completed the WU in 3hr 22min.
It started with client GPU1, but after client GPU1 completed, the next WU (a 5902 as well) started going through at the normal high 6K PPD range.
However, client GPU3 then jumped up to almost 12K PPD. And then when client GPU3 finished its WU, client GPU2 went to nearly 12K PPD
It it somehow tapping the processing power of the idle core? And if so, how?
I'm pretty happy with the output, (Running about 25-26K PPD on all clients on this machine) and if I could just get 5902, I wouldn't need to try and figure out a way to get the 4th core running.
Anybody else experience the same?
Code:
Project : 5902
Core : Unknown
Frames : 100
Credit : 1680
-- GPU1 --
Min. Time / Frame : 1mn 58s - 12301.02 ppd
Avg. Time / Frame : 1mn 59s - 12197.65 ppd
Cur. Time / Frame : 1mn 59s - 12197.65 ppd
R3F. Time / Frame : 1mn 59s - 12197.65 ppd
Eff. Time / Frame : 2mn 02s - 11897.70 ppd
-- GPU2 --
Min. Time / Frame : 3mn 22s - 7185.74 ppd
Avg. Time / Frame : 3mn 25s - 7080.59 ppd
Cur. Time / Frame : 3mn 31s - 6879.24 ppd
R3F. Time / Frame : 3mn 31s - 6879.24 ppd
Eff. Time / Frame : 3mn 27s - 7012.17 ppd
-- GPU3 --
Min. Time / Frame : 3mn 28s - 6978.46 ppd
Avg. Time / Frame : 3mn 33s - 6814.65 ppd
Cur. Time / Frame : 3mn 34s - 6782.80 ppd
R3F. Time / Frame : 3mn 34s - 6782.80 ppd
Eff. Time / Frame : 3mn 32s - 6846.79 ppd
