So I've read the starter guide to overclocking you've got posted here and I've got a few questions.
I'm trying to get my E8500 to 3.8 or 4.0 ghz. I've been able to get it stabilized at 3.2, 3.4, and 3.6. I start having problems at 3.8.
I'm using the chip on an Asus p5q-e Motherboard, with a thermaltake v-1 cooler, and 4gb of OCZ HPC Reaper DDR2 6400 5-5-5-15T 2.1v(stock).
Before I get to my specific settings I'm curious about a couple things. What's the better method to overclock: increasing the multiplier or increasing the bus?
Right now I'm running 400fsb x 9.5 = 3.8
I could also run 475fsb x 8 = 3.8
I'd like to run 1:1 and if I want to get to 4 I'm going to have to overclock the Ram to maintain 1:1, though I'm not sure how feasible that is with the ram I got. It's already charged up pretty good at stock settings.
Anyway, on to my current OC.
I had the CPU voltage at 1.275.
Running the Intel 64 bit Burn test showed no errors and a peak load temp of 61. Not bad. I ran prime 95 64 bit and thread#2 failed at 21 minutes. I restarted the computer to tweak the voltage up a little and it failed to post. I had to unplug the computer to get it to post and then enter in all the settings again. This time I bumped it up to the above values and it's been running stable for about an hour. (interestingly enough, prime 95 64bit small fft's seems to run about 5 degrees cooler at peak load then the Intel burn test at max stress)
Anyway, is there anything I might be overlooking? If this proves stable what should I start tweaking next to minimize heat, or should I try going 500x8 and OC the ram?
So far I gotta say I'm really impressed with this chip.
Code:
Ai Overclock Tuner ................. [Manual]
CPU Ratio Setting .................. [9.5]
FSB Frequency ...................... [400]
PCIE Frequency ..................... [100]
FSB Strap to North Bridge .......... [400]
DRAM Frequency ..................... [DDR2 800]
DRAM Clock Skew on Channel A1 ...... [Auto]
DRAM Clock Skew on Channel A2 ...... [Auto]
DRAM Clock Skew on Channel B1 ...... [Auto]
DRAM Clock Skew on Channel B2 ...... [Auto]
DRAM Timing Control ................ [Manual]
1st Information :
CAS# Latency ..................... [5 DRAM Clocks]
DRAM RAS# to CAS# Delay .......... [5 DRAM Clocks]
DRAM RAS# Precharge .............. [5 DRAM Clocks]
DRAM RAS# Activate to Precha ..... [15 DRAM Clocks]
RAS# to RAS# Delay ............... [Auto]
Row Refresh Cycle Time ........... [Auto]
Write Recovery Time .............. [Auto]
Read to Precharge Time ........... [Auto]
2nd Information :
READ to WRITE Delay (S/D) ........ [Auto]
WRITE to READ Delay (S) .......... [Auto]
WRITE to READ Delay (D) .......... [Auto]
READ to READ Delay (S) ........... [Auto]
READ to READ Delay (D)............ [Auto]
WRITE to WRITE Delay (S) ......... [Auto]
WRITE to WRITE Delay (D) ......... [Auto]
3rd Information :
WRITE to PRE Delay ............... [Auto]
READ to PRE Delay ................ [Auto]
PRE to PRE Delay ................. [Auto]
ALL PRE to ACT Delay ............. [Auto]
ALL PRE to REF Delay ............. [Auto]
DRAM Static Read Control ........... [Disabled]
DRAM Read Training ................. [Disabled]
MEM. OC Charger .................... [Enabled]
Ai Clock Twister ................... [Auto]
Ai Transaction Booster ............. [Manual]
Common Performance Level ......... [Auto]
Pull-In of CHA PH1 ................. [Disabled]
Pull-In of CHA PH2 ................. [Disabled]
Pull-In of CHA PH3 ................ [Disabled]
Pull-In of CHA PH4 ................ [Disabled]
Pull-In of CHA PH5 ................ [Disabled]
Pull-In of CHB PH1 ................ [Disabled]
Pull-In of CHB PH2 ................ [Disabled]
Pull-In of CHB PH3 ................ [Disabled]
Pull-In of CHB PH4 ................ [Disabled]
Pull-In of CHB PH5 ................ [Disabled]
____________________________________
CPU Voltage ........................ [1.29375]
CPU GTL Voltage Reference (0/2) .... [Auto]
CPU GTL Voltage Reference (1/3) .... [Auto]
CPU PLL Voltage .................... [Auto]
FSB Termination Voltage ............ [Auto]
DRAM Voltage ....................... [2.1]
NB Voltage ......................... [1.36]
NB GTL Reference ................... [Auto]
SB Voltage ......................... [Auto]
PCIE Voltage ....................... [Auto]
Load-Line Calibration .............. [Enabled]
CPU Spread Spectrum ................ [Disabled]
PCIE Spread Spectrum ............... [Disabled]
CPU Clock Skew ..................... [Auto]
NB Clock Skew ...................... [Auto]
CPU Margin Enhancement ............. [Optimal Mode]
