Hi There,
The things They Do Not Tell You
Fractal Design Define R4 Black Pearl case. Asus Z87-A mobo.
I have:
Using the SWAG method, I'm guessing that 2 + 3 = fans controlled by the case's fan controller, and 2 + 4 = fans controlled by the mobo.
I'm going to further guess that the mobo will moderate the fan speed based on thermal load, but the case's fan controller...?
Lastly: I'm guessing having the mobo control fan speed: I'll be able to read/monitor fan speed with the O/S, whereas, with the chassis controller: Not.
How did I do?
Thanks,
Jim
I have:
- The two chassis fans
- Two 3-pin female connectors on chassis cables
- Two 2-pin connectors on chassis cables with which the 3-pin connectors in (2) appear to mate
- Three 4-pin male fan connectors on the mobo, which appear to be keyed such that the 3-pin connectors in (2) appear to mate correctly
How did I do?
Thanks,
Jim
