Hello all,
I got bored several days ago and decided to add a third radiator to my loop for some fun. I know there is a point in diminishing results, waste of money, overkill, etc, etc, i just did this for fun and as I enjoy the hobby. My current set up is:
Case - Lian Li o11 Dynamic
i9-9900ks - OC'd to 5.1 at 1.35 VCore
RTX 2080ti - OC'd
Water cooling setup:
EK Velocity CPU Block
EK GPU Block
Corsair Hydro X Series XD5 Pump/res combo
EK Coolstream XE 240 double - top as exhaust
EK Coolstream SE 360 - side intake
Corsair Hydro X Series XR7 360mm - bottom as intake
All rads have corsair mag lev pro fans on them.
Should i bother playing around with the intake or exhaust setup? Should I try all rads as exhaust or all as intake? Reason I ask is after adding the new rad my temps stayed the same with no change in room ambient temp - which could be a result of diminishing results in the loop. I know loop order has not real effect but the one rad at the top is the first ran in the loop order following the gpu and cpu block so its getting all of the heat. pump/res > rad > gpu > cpu > rad > rad. Anyone here ever mess with all rads set to exhaust/intake with 3 rads?
RTX 2080ti - OC'd
EK GPU Block
