IÂ’m concerned with my riser cable touching the backplate while the 3090 is mining that the temps may melt the riser cable. Was thinking about grabbing some of that heat shield from a car enthusiast shop to barrier the riser cable from the heat. Back plate memory getting to the 90Â’s C (200F). How much heat can the riser handle? Thoughts?
Riser is jammed in with orientation of two GPUÂ’s vertical mounted in the loop
