I posted some of this up in this post http://www.ocforums.com/showthread.php?t=534257
but I figured I should make my own thread instead of hijacking that one...
GA-P31-S3L + 4x OCZ2P800R22GK
I've tried putting 4xOCZ 2GB Kit (2x1GB) DDR2 800MHz/PC2-6400 CL 4-4-4-15 PLATINUM XTC in my Gigabyte GA-P31-S3l rev 1.0 MB but it keeps crashing at exactly the same point of booting windows. If I put them in pairs they work fine but as soon as I put all four in, it keeps crashing. doesn't matter which sticks I use in which slots (although I'm keeping them in matched pairs just incase they are not).
Looking up the system manual here http://europe.giga-byte.com/FileList/Manual/motherboard_manual_ga-p31_ds3_ds3l_s3l_e.pdf
I'll papraphrase;
"Because of chipset limitations, do not populate both DIMM sockets of the same channel (e.g. DDRII1 and DDRII2), or populate 4 DIMM sockets with double-sided memory modules to prevent system's failure to start or incorrect detection of memory modules."
Does this make sense to anybody here? Should I be looking for single sided dimms, change my chipset or can I tweak something to make it work?? Has anybody else seen this before or am I the only person to ever want to install 4 double sided dimms on a P31 (with for slots) ?
I'll papraphrase;
