Norbridge and dd2 voltages both at +2 as suggested by the ocz guy. Memtest hung on tet 5.. Never known it to have hung before. Going to try it again, see if it blows in the same place
Ok, an update here. I've been trying the Ram in different configurations and running memtest. What I found was if I put two sticks in the two channell one slots, the machine will fail to post. No errors no beeps. Could this be part of my problem?
its odd to have it happen to 2 slots... but when you try one stick in each slot, 2 slots dont work? yea though if its a bad dimm slot rma it, casue you got 4 1gig dimms...
1 Dimm in one slot is fine. But two dimms in two slots doesn't post. but all four in all four slots posts but crashes memtest after 9 minutes 47 seconds lol
ok but you mean 1 dimm in any of the slots works? if dual channel isnt working correctly then you may need to wait for a bios update. i had to do the same with my AB9-pro 965 based cause of bios issues. when you say 2 dimms though you mean wiether its in dual or single channle mode it still doesnt boot up?
