CarbonSteal
- Oct 9, 2017
Hello everyone,
I have a 4790K laid inside a Gigabyte Gaming 7 Z97X. The chip runs stable at 4.7 GHz and 1.275 V 24/7, although I have been running 4.5 GHz at 1.24 V with offset typically.
As previously mentioned, I have had no issues with the overclock's stability with actual tasks, only waking out of sleep. I know most overclockers don't value sleep, but I do. I have tried fixed voltages with the stock 100 MHz BClock, and offset from the stock VId. Either overclock will wake out of sleep successfully 2 or 3 out of 5 times. The others will result in a BSOD. Every single BSOD has the stop code: 0x8000400000000002, which also happens to be the stop code I get usually when my VCore is knowingly too low. If my overclocks are stable up top at a fixed voltage, how can the sleep states not be? It seems voltage related. I have not messed with Load Line Calibration or PLL Overvoltage. I have heard that you must disable PLL Overvoltage to get Sandy Bridge to sleep. Is this true? Same with Haswell?
My PSU is an EVGA G2 750 W, which EVGA swears is "Haswell-compatible" (C6/C7).
I like to know how everything works, so can someone explain to me why the PLL Overvoltage would need disabled, if relevant at all?
Thanks for any insight.
