- Aug 19, 2012
OK now we can sort out your OC this is what i want you to do!!
Go into the bios and set the MULTI to 42 and what we are trying to do is get this stable first, so we have a stable base to start and go back to as well!!
Next set your RAM SPEED in the correct box that is 2133mhz!!
Next we will set your CPU Voltage @ 1.300v
Next your Ram Voltage 1.65volts in the DRAM VOLTAGE BOX CHA,CHB!!
Then also CHC AND CHD as well both @ 1.65volts in both boxes!!
Then you can click on your DRAM TIMING CONTROL and go into that and set your timings manually!! Its 9-11-11-31-2 these are your timings for that ram!!
This is what your looking for in the Bios!! Just fill in the boxes like i have with your numbers!! When finished F10 SAVE AND REBOOT!!
Now do this first then we will do some more after this!!
AJ.
AJ.
