What speed is the ram at? If you are not at 1:1 ratio (FSB:RAM), you can lower that without changing the timings, but, then again, Im running blind here...and should probably not respond. LOL!
Try setting it to 9-9-9-27, increasing DRAM voltage to 1.6.
Also try bumping up your CPU VTT voltage a bit. Your vCore should be enough for a near 4GHz OC.
Don't set the ratio at auto...you need to drop the DRAM ratio to force your RAM to a slower speed.
