- Thread Starter
- #21
I'll put money on the bus clock fluctuation. Most ASUS boards fluctuate but yours seems a bit worse than normal. I see it dropped down to 194 which is ~ 150 MHz. You could try a different BIOS and see if that straightens it out. If not you either live with it or try and RMA the board if it's still in warranty
As long as its nothing that will die later on ill ignore it. I was just worried there was a problem. This is the second crosshair ive had and i am not going to rma it again. Takes to long. Id rather save up money and build a better system.
