hi guys. I added a new 4GB RAM onto my PC hoping to make it run on 8GB, but I found on Window > System that only 3.25GB are usable out of the 8GB. I have tried all solutions on Google but none of it work. Does anyone using similar hardware run into similar problems? Looking forward to your replies.
My PC:
OS: 64-bit Win 7 (Home Premium)
Mobo: Foxconn G41MXE (BIOS ver: P07)
CPU: Intel Pentium Dual-Core E5700 3ghz
Graphic: Geforce GTX 560 Ti
RAM: 2X 4GB Elite 1333 double channel
Solutions I have tried so far:
1. BIOS upgrade
2. Turn on memory remapping under BIOS
3. Turn on/off Memory Hole under BIOS
4. Disable Integrated Graphic Adapter
5. Uncheck "max memory" under MSCONFIG
My PC:
1. BIOS upgrade
