hey guys,
i´ve been reading up on your forum last few days a lot and tried most of solutions offered relative to my problem.
so i´ve built a new rig found on the following link:
https://pcpartpicker.com/user/monch147/saved/n4RkTW
and everything technically works, but i´m having some problems with the RAMs. When i boot into OS and open system info it says 16Gb installed (7,95Gb usable). Iin bios both sticks record 8Gb separately.
Than i head to Resource manager and it says there a little over 8Gb is hardware reserved. My mobo does not have integrated graphics so it shouldn´t be that, i´ve made no virtual drives and my graphics card has a 4Gb GPU of its own.
Additionally i´ve tried the msconfig way with limiting memory, checked and unchecked and restart after every change. Additionally i tried disabling paging file, which i now returned to 400-1024Mb.
I´ve tried testing both sticks and when i have only one ram installed OS can use it all, i´ve also tried just switching their position, i´ve tried changing a-xmp profiles from default 1 and 2 to changing the dram specs such as latency and voltage to specified 16-18-18-18-38 and 1,35V.
I´ve been emailing with msi support, while g.skill hasn´t responded in over a week.
So the msi people supplyed me with latest bios i guess.
I had .150 version bios which i downloaded as most recent from their download center, and they send me a link to .160 version, but it did nothing as far as this problem is concerned.
I suspect the problem is software related, and would appreciate any idea or possible solution you guys might have.
