hank123 Member Joined May 25, 2007 Location With Yahweh in Colorado Dec 4, 2013 #1 Seems I can not find a 7970 cooler. Any ideas?
Ajay57 Member Joined Aug 19, 2012 Dec 6, 2013 #2 I don't know your requirements are for this Cooler or the size of the case it fits into, but i you look at the Google post, there is good choice!! 1, https://www.google.co.uk/search?q=7...j7&sourceid=chrome&espv=210&es_sm=93&ie=UTF-8 So kindly check them out and choose what you like!! AJ.
G gsrcrxsi Member Joined Feb 21, 2008 Location Baltimore, MD Dec 6, 2013 #3 there was a 7970 version of the Arctic Cooling Accelero Xtreme III, but sadly it's been discontinued. you can use the regular version of the XIII if you use the EK Cu Adapter. but temps arent as good as with the native cooler. i will be doing the latter on my 7950
OP hank123 Member Joined May 25, 2007 Location With Yahweh in Colorado Dec 7, 2013 Thread Starter #4 gsrcrxsi said: there was a 7970 version of the Arctic Cooling Accelero Xtreme III, but sadly it's been discontinued. you can use the regular version of the XIII if you use the EK Cu Adapter. but temps arent as good as with the native cooler. i will be doing the latter on my 7950 Click to expand... artic cooling I know.
OP hank123 Member Joined May 25, 2007 Location With Yahweh in Colorado Dec 10, 2013 Thread Starter #5 Accelero Xtreme III works on it correct? Im sorry im so far out of the game at this point. Family and stuff has me all tied up. If it works ill find one. Thanks all!
G gsrcrxsi Member Joined Feb 21, 2008 Location Baltimore, MD Dec 10, 2013 #6 Like I said above. Yes it will work but you need the EK Cu Adaptor for it to work. If you get the AC Xtreme 7970 version it will work without any adapters.
