- Nov 12, 2002
- Rootstown, OH
The 8800 GTS 320MB will be my next victim.
Loaded it up today, but I didn't LET far enough down the card - PWM section of the card got wet and the card started bugging out.
Before that happened, I did get a few runs in of 3DM03 though. This was the best so far:
16th place on the card. Good for 23 User points, and 24 Team Power points... The card isn't topped out yet, thats just as far as I got it before the moisture got the best of it. In the garage as always, and its really humid. Condensation has been major grief since the end of winter.
The card bugs out between -50 to -60C, so it likes it pretty warm. GPU volts are at about 1.55V. I haven't tested max GPU clocks, mem clocks, or shader clocks yet - it just kept doing all the settings I threw at it.
More to come, got things drying out currently then will fix the insulation problem before I run it again.
