- Apr 6, 2002
so i'm running some tests for another review using an 890gx motherboard. The onboard video works great and so does an hd5550 pcie card. But when I throw an nvidia gt240 in, the card won't display anything. The fan spins and the system boots fully into linux but never enables the display on any port (dvi, vga, or hdmi). POST doesn't even display so it can't be drivers. The card works in another system, so its not the card. And another pcie card works in this board (the hd5550) so its not the pcie slot.
bios is as up to date as i can get it. I've tried fully disabling the onboard video but i get the same result.
i just remembered I have a 7950gt sitting around so I threw that in and it worked perfectly. the 7950gt has a power plug on it which made me think "hmm, maybe the gt240 isn't getting enough power" but it has no extra power plug and the board doesn't have one of those "extra pcie power" plugs either. Every power plug on the board is used. Is this board simply not supplying enough power to the card thru the pcie slot?
