I used to have 4 sticks of 1gb OCZ platinum DDR2 800 RAM 4-4-4-12 2.1v. Recently I upgraded to 8gb of ram, 2gb crucial ballistix DDR2 800 4-4-4-12 2.0v. The first thing I noticed is my board temperature run about 5-7C hotter than when I was using 4gb of ram, is that normal? Initially I thought it was the thermalpaste going out, so I replaced it with a fresh layer of AS5. I just did a over night of prime95 blend, it was stable for 10 hours+ until I stopped it this morning.
Spec
Asus P5k-E motherboard with thermaltake spirit copper NB cooler
E8500 E0 @ 4209mhz 443x9.5 with thermaltake cl-p0024 cooler 92mm vantek stealth fan
8gb crucial DDR2 800 run at 887mhz 5-5-5-15
Corsair CX400 power supply
Asus GTS250 1gb 740/1836/2200
Antec 300 case
Temps
CPU idle = 31/38c, load with OCCT linpack64 bit = 70/71c, prime95 small fft = 58/55c
Board idle = 38c, load with prime95 large fft = 51c (used to be 44 - 46??)
GPU idle = 35c, load with OCCT GPU test = 70c 25% fan speed
BIOS setting
Ratio = 9.5x
Strap = 333mhz
FSB = 443mhz
DRAM = 887mhz 5-5-5-15 2T
PCI-E = 100mhz
Transaction booster = enabled level 3
CPU VCore = 1.3375 (1.32v idle 1.312v load in windows)
CPU VTT = 1.10v
CPU PLL = 1.50v
NB = 1.4v
SB = 1.05v
Memory = 1.90v
Load Line = Enabled
CPU GTL = Auto
NB GTL = Auto
CPU Spread Spectrum = disabled
PCI-E Spread Spec = disabled
I tried to o/c the ram to 4-4-4-12 @ 2.0v, it failed memtest86. I upped all the way to 2.2v with 0.05v increment, no luck. I tried 1064mhz 5-5-5-15 @ 2.0 - 2.2v, no luck either. Should I go higher with the voltage? I used to run 4 sticks of 1gb ocz platinum ram 1064mhz 5-5-5-15 or 887mhz 4-4-4-12 @ 2.1v without any issues.
Thanks
Spec
Antec 300 case
Temps
BIOS setting
Ratio = 9.5x
Strap = 333mhz
FSB = 443mhz
PCI-E = 100mhz
CPU VTT = 1.10v
CPU PLL = 1.50v
NB = 1.4v
SB = 1.05v
Memory = 1.90v
Load Line = Enabled
CPU GTL = Auto
NB GTL = Auto
Thanks
