I see so many odd comments on these forums about AMD and gaming(mostly in other sections) that I figured I'd toss this out there. The TL: DR is that AMD processors have added cores to achieve good cumulative performance while Intel has gone with more powerful cores. The end result is more uniform and generally better performance from Intel in gaming, sometimes AMD is close and sometimes AMD is on a much lower level. The rest of this thread is based on two sets of GPU-z and CPU core usage screenshots.
My system:
1045T @ 3.7Ghz
7850 2Gb @ 1081MHz core, 1375MHz memory
8Gb of RAM
The focus here is on the red bars(the GPU Load one especially), the CPU usage is included to show what works well on our processors and what doesn't.
A couple of well-made games that work great on AMD and Intel
Lots of cores being used fairly effectively results in great performance. Especially considering that the Phenom II line doesn't do as great as Bulldozer/Piledriver in Far Cry 3....and mine is only running at 3.7Ghz.
5 Poorly made games that only run great on Intel, while being mediocre to poor on AMD(Warning: long image)
There are many games available that look like these. AMD processors have been focusing on an increased number of cores to achieve cumulative power while Intel processors have been developing stronger cores. So lazy game developers cram a lot in to games that only use a few cores and while Intel is ahead by a small margin in well-made games they are now on a whole other level of performance.
When I play the bad games noted here on a stock 3570 or an OCd 3770 they run anywhere from quite smooth to perfectly, but they obviously aren't that way if you don't have excellent performance per core and no AMD processor offers that.
So if somebody says "I have an FX-6300 and a 7950, sometimes I get low FPS, should I get another 7950" and somebody just blurts out "yes, I play 2 games and they run great on my 6300" tell them they need to know a lot more before they go telling somebody to attach $500 in GPU to a stock clock $130 CPU. Sometimes the right upgrade for gaming is to buy Intel, it all depends on what you play.
Edit: You can overclock the latest AMD 6/8 core processors to 5Ghz and easily outperform my 1045T in the bad games but even if you achieve 50% more CPU performance(which I doubt) they'll still be behind a stock 3570k (about 60-70% better per core than my [email protected]) in the poorly made games and some of them will still not run smoothly.
Double Edit: I will be trying to get ahold of the 3570 machine to toss my 7850 in for comparison, but I may end up just buying one soon anyway.
My system:
1045T @ 3.7Ghz
8Gb of RAM
