- Oct 11, 2002
- The Empire State
No problemo, that's we're all here for. Just be sure to post back your results
Good luck!
Good luck!
A64Info http://www.xtremesystems.org/forums/showthread.php?t=96678jasonaerts said:Nebulous. These will help out allot,
jasonaerts said:Ok sorry dont mean to sound dunce here but are you saying i should lower my V-core a bit?
Also my current settings (untested)
FsB/htt 220
SB to Nb 200
PCIE 100 default
Proc freq multi 11X (note my does not go to 12x?)
V-core 1.425
HT 4x which brings me to 880, if im doing this right
Mem clock 183
Cas 3.0
Tras 8clk
Trp 4clk
Trcd 4clk
T2/T1 set auto (shows 2T on CPU-Z)
Any thoughts, temps are norm ive got Prime running now one for each core
thanks
jasonaerts said:Ok i have changed my HT back to 5x that seems to have fixed the lag. very snappy with 2 primes running one per core.
is there anything else i can do to sharpen this even more, im thinking 2.4 is a good oc for now, how about mem? volt?
jasonaerts said:Hello to everyone, this is my first post on this forum and its rather selfish sorry but i dont have much to offer in the form of Knowledge here quite yet.
A8N32-SLI DELUXE
AMD 64 X2 4400+ TOLEDO 90NM
BFG 7950GT OC'ed to 590/1600
Audigy 2 Zs
2 Gigs Budget DDR 400mhz Ram
WD 250g SATAII
500 Watt Neo HE pwrsply
I am somewhat aware of the wealth of information here on these forums and am thankfull to have found them, i am sure there is a guide to doing what i am asking which is to OC my setup but i was really hoping for someone to hold my hand on this one as this will be my first attempt at overclocking and i really dont want to hurt my hardware as it took me 13months to save up for it and cant be replaced easily.
If there is anyone out there willing to give me this sort of attention i would be most grateful.
Thanks in advance =)
Jason
55°C is still OK but you're starting toward the Red Zone (60°C). Lower volts = lower temps so if you can turn the vCore down and still keep your OC then do it. Since you're already over-clocked I wouldn't back down to 1.35v (1.15v + Overvolt) right away. Try turning it down 0.25v at a time until it won't boot with the settings you have now, then turn it back up 0.25v. If your chip is anywhere close to average you should be able to get a least 2600-2650 on the stock cooler but trust your temps and stay under 60°C under 2xPrime95 load.jasonaerts said:ok all of the above is the same except i have change my
FSB to 240 and multi to 10x
Ran for a while fine then just rebooted (2xprime/one per core, was browsing the net, then i tried winrar making an sfx archive)
Then i remembered i had forgotten to change my memclock so i changed that to 166 which brings me right back to 200mhz. running same test set up now load is at 55c not sure if i like that, or if it is within a reasonable range.
QuietIce said:55°C is still OK but you're starting toward the Red Zone (60°C). Lower volts = lower temps so if you can turn the vCore down and still keep your OC then do it. Since you're already over-clocked I wouldn't back down to 1.35v (1.15v + Overvolt) right away. Try turning it down 0.25v at a time until it won't boot with the settings you have now, then turn it back up 0.25v. If your chip is anywhere close to average you should be able to get a least 2600-2650 on the stock cooler but trust your temps and stay under 60°C under 2xPrime95 load.
It doesn't matter how fast your machine is running right now, if 2xPrime95 checks out for ~15 min. and you can run a SuperPi 2M test then increase the FSB again and test again. If the test fails (and your temps will allow it) increase the vCore another 0.25v. Also, I'd keep the 11x multi - the only good reason to go with a lower multi (and higher FSB) is to increase the RAM speed and you're already using a divider to turn yours down.
BTW - How fast did the HT bus run before it locked up ...?
