Is this board worth its price?
Can you guys suggest the best Abit board for me? Heres what Ill be running just need a mobo..
Case- http://www.newegg.com/app/ViewProductDesc.asp?description=11-119-023&depa=1
Cooler Master Wave Master Case without Power Supply, Model "TAC-T01-E1C"
Case Type: Mid-Tower
Color: Silver
Material: Aluminum Alloy
Drive Bays: 4x5.25" & 5x3.5"
Expansion Slots: 7
Power Supply: No
Cooling System: 2x80mm Fans
Mainboard Compatibility: ATX,12"x9.6"(30.5x24.5mm)
Dimensions: 540x198x458mm
Special Features: Stylish curved front plate design;Sophisticated machine processing for exotic smooth finish;Removable motherboard tray for fast and easy assembly.
PSU- http://www.newegg.com/app/ViewProductDesc.asp?description=17-104-150&depa=1
OCZ PowerStream 420W Power Supply With Adjustable Power Rails With LED Indicators, SATA Connector, Model "OCZ420ADJ"
Type: ATX
Maximum Power: 420W
Input Voltage: 100-120V AC/200-240V AC
Input Frequency Range: 60/50Hz
Input Current: 10/6A
Output: +3.3V@28A, +5V@30A, +12V@30A, [email protected], [email protected], [email protected]
Approvals: TUV, UL, CSA, CE, CB, FCC
Features: OCZ PowerWhisper Technology, OCZ PowerFlex™ individually adjustable power rails with LED indicators. OCZ ConnectAll universal connector. (ATX, BTX, SATA, P4 and EPS12V), OCZ PowerShield power leads for VGA and HD. 5 year warranty backed by OCZ's exclusive PowerSwap replacement program.
CPU- http://www.newegg.com/app/viewproductdesc.asp?description=19-116-197&DEPA=1
Intel LGA 775 Pentium 4 640 3.2GHz 800MHz FSB, 2MB L2 Cache Processor w/ Hyper Threading Technology
Model: Intel Pentium 4 640
Core: Prescott
Operating Frequency: 3.2GHz
FSB: 800MHz
Cache: L1/12K+16K; L2/2MB
Process: 90 nm
Socket: LGA 775
Multimedia Instruction: MMX, SSE, SSE2, SSE3
Features: Support Intel EM64T, XD Bit, Enhanced Intel Speedstep Technology
Manufacturer Warranty: 3-year MFG
Packaging: Retail box (with Heatsink and Fan)
MEMORY- http://www.newegg.com/app/viewProductDesc.asp?description=20-145-526&depa=1
CORSAIR VALUESELECT Kit 240-Pin 1GB(2 x 512MB) DDR2 PC2-4200, Model VS1GBKIT533D2
CORSAIR
Speed: DDR2-533(PC2-4200)
Type: 240-Pin DDR2 SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 4
Support Voltage: 1.8V
Organization: two 64M x 64-Bit
Bandwidth: 4.2GB/s
Warranty: Lifetime
DVDr/w;CDr/w Drive- http://www.newegg.com/app/ViewProductDesc.asp?description=27-131-338&depa=1
Plextor 16X Double Layer DVD±RW Burner with s/w and Black and Beige Bezels, Model PX-716A/SW
Write Speed: 4X DVD+R DL, 16X DVD+R, 8X DVD+RW, 16X DVD-R, 4X DVD-RW, 48X CD-R, 24X CD-RW
Read Speed: 48X CD-ROM, 16X DVD-ROM
Interface: ATAPI / E-IDE
Buffer: 8 MB
OS Support: Windows XP/ 2000/ ME/ 98SE
Features: Intelligent Recording technology supported for recording at high-quality and optimum speed
Packaging: Retail box (see pictures for details)
Hard Drive- http://www.newegg.com/app/ViewProductDesc.asp?description=22-148-069&depa=1
Seagate 160GB Barracuda 7200.7 7200RPM SATA with NCQ Hard Drive, Model ST3160827AS-RK
Capacity: 160GB
Average Seek Time: 8.5ms
Buffer: 8MB
Rotational Speed: 7,200RPM
Interface: Serial SATA 150
Features: Up to 20 percent performance improvement over previous SATA, 100 percent software compatible with existing PCs
Manufacturer Warranty: 5 years
Packaging: RETAIL
Vid Card- http://www.newegg.com/app/ViewProductDesc.asp?description=14-130-214&depa=1
EVGA nVIDIA GeForce 6600GT Video Card, 128MB GDDR3, 128-Bit, DVI/TV-Out, PCI-Express, Model "128-P2-N368-TX"
Chipset/Core Speed: nVIDIA GeForce 6600GT/500MHz
Memory/Effective Speed: 128MB GDDR3/1000MHz
BUS: PCI-Express x16
Ports: VGA Out(15 Pin D-Sub) + TV-Out (S-Video/Composite) + DVI
Support 3D API: DirectX 9(Shader Model 3.0), OpenGL 1.5
Max Resolution@32bit Color: 2048X1536@85Hz
RAMDACs: 400MHz
Cable/Accessories: HDTV Cable, DVI to VGA Adapter , Manual, Driver CD
Just wondering whats the best Abit motherboard for me given the hardware listed above, thx.
Color: Silver
Expansion Slots: 7
Power Supply: No
Type: ATX
Maximum Power: 420W
Core: Prescott
FSB: 800MHz
Process: 90 nm
Socket: LGA 775
CORSAIR
Cas Latency: 4
Bandwidth: 4.2GB/s
Warranty: Lifetime
Buffer: 8 MB
Capacity: 160GB
Buffer: 8MB
Packaging: RETAIL
RAMDACs: 400MHz
