- Feb 20, 2003
- Buffalo NY
Nice thread and info Evilsizer, seems I'm a little late to the party, but figured I would get subscribed and see what I can use for my IP35 Pro and Q6600 G0.
oh well i have the new bios in for the last wk so far. and all seems good. but i see there wasn't anything new it as well, like new or better settings or choice. but i do have H2O on the cpu, but it is the stock set up that this case came with. sept for the cpu block, i got the Dangerden's TDX block for this cpu.stick with the bios you have, bios 14 is best for 65nm cpus. if your running 45nm then bios 16 or 17 beta are ones you prolly want to use. running over 1.55v on 65nm i wouldnt.. you either need better cooling to get temps down to lower the voltage or its time to switch to a 45nm cpu. as you can see by my sig i have a [email protected], yes im runing bios 16 atm.
this thread helped me out tons..
Disconnect raid array and got the first error I got again..
windows could not set offline locale information Error Code: 0x80FE0000
thats something i have never come across, something may have gotten fubar'd after turning off raid.
ah for some reason i read that you were.... any change you got vista ichx/AHCI drivers to it to install on boot up?
highly possible but could be something else really hard to tell without tring another drive.I tried that and it then said no drive found? go figure..
I mean the drive lights up in conjuntion with the dvd drive, just wont finish..
I am wondering if I got a bad disc at this point.
Like I said I had the RC2 copy running on it just fine during beta.
thats whats killing me..
