Hello,
This is my first foray into overclocking and I an not really getting anywhere...
The equipment:
MOBO: Abit NF-M2 w/ GeForce 6150
CPU: AMD 3800+ X2 (AM2, 89watt)
RAM: Patriot PC2-6400 800MHz, 2X1GB, 4-4-4-12, 2.2V
PSU: 450 Watt FSP
My problem is, as the title says, I just cant get my FSB above 205. At 205 it boots just fine with no adjustments to anything else. At 206 however, I get this in the POST screen
Warning! Now system is in safe mode
Please re-setting CPU Frequency in the CMOS setup[sic].
It then allows me to boot at 200 (the default) or go into the BIOS.
I have tried (with the FSB at 206)-
- upping the CPU voltage to 1.375, 1.400, 1.425 and it still wont let me boot.
- Lowering the multiplier from 10x to 9x and below on to 5x
- Changing the RAM timings. The default my board gives is 5-5-5-16, 1.8V. I adjusted it to the RAM's specification of 4-4-4-12, 2.2V. Nothing. I also tried running the RAM at 667 and 533.
- I even tried replacing the button battery
What should I try next!?!
Note: I dont think this mobo has what I read is a 'memory divider'... Is a memory divider the same as lowering the memory to 667 etc?
The equipment:
PSU: 450 Watt FSP
