- Jan 15, 2001
EDIT: I've been suggesting lossless as the "best", but I highly recommend you investigate the lame mp3 encoder. lame --alt-preset extreme renders CD quality. Don't just take my word for it. Test it yourself.
To give you idea on filesizes...
The track in question is, "World in my Eyes, by Depeche Mode's Violator Album."
CD rip: 45 MB
FLAC encoding: 28 MB
MP3 "insane" 320 Kb/s : 10.5 MB
MP3 "extreme" VBR : 8.2 MB
All of these sound identical. In fact, there have been tests with $15,000 equipment in which a number of audiophiles have not been able to discern a difference between 256 Kb/s and up mp3s.
The best recommendation is to be judicious in your encoding. Not every piece needs lossless encoding. For those that do (or your favorite CDs) go for it. For the rest. You have some good alternatives.
http://www.3dsoundsurge.com/ has a good article on creating better mp3s. I suggest you take a look around.
As was mentioned previously by myself and MospeadasDark lossless encoders are what you're after.
You'll be hard pressed to do better than lossless encoding. (If you find better please share it.)
I can't tell the difference between the original CD and the flac encodings. This is with rather expensive audio equipment as well.
Something I think bears mentioning: Ensure that your CD/DVD drive is up to snuff. If the original rip isn't perfect, even the best encoder will be useless. For windows I recommend EAC. Exact Audio Copy.
http://www.exactaudiocopy.de/
If you're in linux. A program named Grip will be more than adequate.
http://nostatic.org/grip/
Happy listening.
CD rip: 45 MB
Happy listening.
---X--- said:
What about encoders?
