This is my first atempt at water cooling. It was a long time comming, as I have wanted to build a sick gamming rig and just never set aside the time to do it.
So finaly here it is. I started by using a lian li v1000b case and modded olot more than I thought I would becaus I realy realy wanted everything to fit within the space of the case. I would consider mounting the rad outside the case only if I move to TEC cooling. I almost purchased a TEC setup but voted against it at the last min. I thought maybee getting a little experence under my belt could only help me.
So all sugestions are more than welcome, in fact encuraged. Setup is as follows:
Hardware:
CPU: opteron 148 (cabye) didnt get the other numbers before storm mount
MB: DFI Ultra-D w/ sli mod
GPU: 7800GT
Mem: Mushkin redline XP4000
PSU: OCZ powerstream 600w (OCZ Modstream 520 in pics)
Sound: audigy 2 ZS
HDD: 2X 36 GIG raptor Raid 0 (1 in pics)
W/C Setup
Pump: mcp 350 modded to 1/2" barbs
Rad: BIX II
Fans: 2x panaflow 100 cfm in pull config
Tub: 1/2" ID McMasterklear W/ worm drive clamps (super happy W/ it 2)
CPU Block: storm
GPU Block Maze 4 (W/ OCZ Ramsink W/ Sekisui #5760 Thurmal tape )
Temps are a little under 31C and 34C on load untill I go to 1.6V on CPU then it goes up to 41c or so the best ive done with those kinds of volts are:
HTT: @ 318
CPU: @3.18 ghz (X10 obv.)
Mem: @265.5 (using 166 devider) W/ 2-2-2-5 timmings @3.7v
With this setup it passes 32m superPI, 3dmark 05, pcmark 05, but wont post into windows untill I lower it down. So totaly stable I am @:
HTT: @291.2
CPU: @ 3.203 GHZ on 1.61 v
MEM: @246.4 w/ 183 div. timmings 2-2-2-5-7 @3.5v using 4v jumpr
I will post some screen shots when I g onto that computer I had all these pics on this computer so I will post to this thread again when I have time....
Hardware:
GPU: 7800GT
Sound: audigy 2 ZS
W/C Setup
Rad: BIX II
CPU Block: storm
HTT: @ 318
HTT: @291.2
