So apparently, ACC is built into Phenom IIs,
I declare this thread useless.
EC AOD-ACC is described as Embedded Controller for AMD OverDrive- Advanced Clock Calibration, which is the newest feature comes from AMD SB750 southbridge chip, destined for use AMD 790X chipset, is set to allow AMD Black Edition CPUs to be overclocked through AMD OverDrive™ utility further than was previously possible.
I guess there's still a lot of debate on the subject. I just look at results. If the M3A32 (SB600) board can consistently deliver OC's as high as the "common" SB750 boards then, IMO, there isn't enough difference to be a difference, ya' know ...?i have herd its not needed for Phenom2's, i acually only read this a minute ago in the AMD processor section
Phenom II doesn't benefit from the ACC fabric in SB750 / MCP79. The 'benefits' are built in. That aside, SB710 is the same SB700 with fixes to the internal clock generators that were discovered in batches of SB700.
