Mobo - Asus F1A55-M LX Plus
CPU - AMD A8-3870k
Graphics - PowerColor AX6570 1GBK3-H Radeon HD 6570 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready Video Card - dual graphics set up
RAM - Pareema 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model MD316C81609L1 - 2 of these for a total of 8gb
Antec Gaming Series One Black Steel ATX Mid Tower Computer Case
After market cooler - Cooler Master 212 EVO
USB 3.0 PCI card - SYBA USB 3.0 2-port PCI-e Controller Card, VLI VL80x Chipset, with On-board 20-pin HeModel SD-PEX20122
I have tried a lot of overclock options finally got to FSB = 108 and multiplier = 32 for 3.456MHZ.
Ran cinebench (both CPU and OpenGl) - no issues
Ram Prime95 for 2 hours - no issues (max CPU voltage 49%)
Ram memtest86 multiple times - no issues (overclocking FSB > 108 gives memory errors...i know I skimped on the RAM but i'm sure I think I'm stable with RAM at 108 FSB)
Ive run multiple SiSoft Sandra benchmarks - no issues
I go out and leave the PC idle for several hours and then when I come back it gives me that access violation above. I switch off the machine to restart but I just noticed that I need to up the screen resolution so I can get to the task bar so probably can just ok the message.
btw the mobo only had one fan header (3 pin) for the chassis fan so i got a y splitter cable and am powering the top and rear chassi fans from one header using this y splitter cable.
So I dont know if I have an issue because of overclocking or because of AI suite. i really want Ai suite as it gives me a lot of fan sppen and real CPU clock rate (CPU-Z clocks down because of cool and quiet)
Anybody seen this or suggest what this could paossibly be?
P.S. while writing this post my CPU is at 5 degrees C max 13 (Core Temp)
thanks
CPU - AMD A8-3870k
thanks
