- Oct 19, 2001
- newfoundland, canada
Is it possible to upgrade RAM on a Netbook? Is all RAM for Netbooks the same? I found a 2GB stick for my wife's Netbook on Ebay for $55. She has only 1Gb right now. Would it be worth it?
Ok, so it's not a dual core netbook but a single core with hyperthreading enabled.
Should just be the one pnael on the bottom to remove to get to the RAM.
That's strange, device manager shows a multiprocessor cpu and task manager shows 2 CPU load windows.
also at 55 bucks for a 2gb ddr2 sodimm is a complete ripoff...
if the ram is replaceable... which most likely it is. then any of these will work.
http://www.newegg.com/Product/Produ...07609 600006176 600000406&IsNodeId=1&name=2GB
