Hi,
I've been a bit confused about RAID and other hard drive options so am looking for a little clarity. I have an HTPC currently with two 3TB drives with Windows 8 installed onto a separate SSD.
Now what I'm trying to get is some sort of large volume which I can add to. So I currently have those 2x3TB drives but will certainly want to add to them (i have space for 6 or 7). I think something like a RAID5 array would be best, but I was under the impression you couldn't expand RAID5 arrays with additional drives. Is that correct?
(I understand I'm going to need to get at least one more HDD to bring the total to 3)
Even if it can my motherboard can only do raid 0 or 1 so I would probably just use software RAID.
So i suppose my question is: Can I expand RAID 5 software arrays in Windows 8? If not can I do that with these new Storage Spaces?
If I can't expand storage I guess the only way is to backup onto other drives and then restore back onto a newly created RAID array. This just sounds expensive.
Thanks
Thanks
