- Nov 24, 2011
I am looking at some cheap mechanical toggle switches
i wanted to use one on a fan controller (integrated in a Fractal R4 case) that runs 3 fans (only 2 have LEDs)
the controller uses both the +5v and the +12v wires on the molex plug
I want to use the other to turn some LED lights on/off (not the entire roll, 3ft (0.9144 M) or less)
this would only use the 12v wire
the switches are rated in AC (5A @ 125Vac, 2A @ 250Vac)
This is the raiting on my PSU
are those switches able to handle the power? i have limited space for larger ones, larger ones will be iffy
