- Apr 26, 2012
- New York, USA
When I built this computer earlier this year, I really wanted to cool it under water from the start. As I sat down and really considered what I wanted out of this system, I decided that I would rather go with better (and more) hardware at first, and then put it under water next year. Well, I just got the definite OK from the woman that I can indeed spend up to $1000 (or more, if I can justify it to her) to purchase the required parts. So, I got onto performance-pcs.com, and started a wishlist. Then, I thought: "you know, I should really ask for some advise", so here I am. I've had the loop pretty well envisioned since I assembled this system, but I'd like a second opinion. Here's the general idea:
My apologies for the terrible quality of the picture, I lost the cord to my camera, and haven't found a card reader I care to spend money on.
Anyway, as you can see, I intend to replace my current 3.5" 1TB storage drive with a 2.5" of at least 1TB, so I can use one of the 2.5" drive caddies next to the motherboard tray, and free up all of that space the drive cage is taking up. There are mounts for 2 120/140mm fans on the bottom of the case that I intend to populate with low noise (as close to silent as possible), high airflow fans, though I will need to buy a magnetic dust filter for those intakes. I had an afterthought after I edited this picture, and decided that instead of using a 120.2 rad, I may use a 140.2 rad in the front, and replace the front 140s with low noise, high static pressure fans. Either way, the fans will need to be replaced. I'll also be replacing the rear fan with a fan matching the bottom two.
So here's the first series of questions: Which rad would be better? Can I mount the fans in the stock location, with a radiator gasket between the fans and fan mount/case frame and between the fan mount/case frame and the radiator and get adequate pressure?
Anywho, I have the GPU and CPU blocks picked out (EK blocks for the GPUs and a custom Apogee for the CPU), but I'm also unsure whether I should go with 120.3 or 140.3 for the top rad. I believe the 750D supports a 120.4 on top as well, but would that be better? I also need a pump/reservoir combo. I was thinking a bay style reservoir, but I'd prefer it be a single bay if possible, and obviously the pump has to be powerful enough to push through everything.
The plan is to run from the res/pump -> front rad -> GPUs -> CPU -> top rad -> res. I want the runs to be as strait as possible, and I want to use compression fittings (preferably ones with blue accents), so I also need to figure out the count on those too. Is it better to run the GPUs in parallel or series, or does it make a difference? I'd rather use tube than an SLI bridge thing, I think it looks better.
So, the final series of questions: What rads and fans should I go with? I don't want it to look cramped, but I do want the best cooling possible. What res/pump should I get? What/how many fittings will I need? And finally, is there anything I'm missing?
I've chosen Primochill UV-blue tubing, and I'll be running distilled water with a silver kill coil.
I've read the stickies, planned the loop as best as I can, and I think I'm ready for the plunge. Thanks in advance for your help!
