- Aug 26, 2007
- Dayton, Ohio
I've been out of the loop for a while and am looking to actually build a decent rig. My use age varies considerably, try out Linux distros, or dualboot and VM, media editing, 3d modeling, light gaming, media playback, typing, internet browsing etc. Gaming is dungeons and dragons online, so not extremely graphics heavy, and I don't care about max settings.also want to be able to reuse parts as much as possible when I upgrade in the future e.g. cases don't usually break, PSUs can be used on more powerful rig, etc.
I read a few good reviews about the new amd processors and that they worked for wow on med settings reasonably well, so I figured ddo would be fine as well. Mostly would be doing movie playback.
Don't need an OS, monitor, or DVD drives, have plenty laying around.
Looking for advice on better parts or cheaper parts.
bacfrombasicbuild
https://secure.newegg.com/WishList/MySavedWishDetail.aspx?ID=30255688
Fractal Design Define Mini Black Micro ATX Silent PC Computer Case w/ USB 3.0 support and 2 x 120mm Fractal Design Silent ...
Model #:FD-CA-DEF-MINI-BL
Item #:N82E16811352011
Return Policy:Standard Return Policy
In Stock
$99.99 $99.99
1
ASUS F2A85-M PRO FM2 AMD A85X (Hudson D4) SATA 6Gb/s USB 3.0 HDMI Micro ATX AMD Motherboard
Model #:F2A85-M PRO
Item #:N82E16813131883
In Stock
Mail in Rebate Card
$129.99 -$10.00 Instant $119.99
1
CORSAIR AX860 860W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS PLATINUM Certified Full Modular Active PFC Power Supply
Model #:CP-9020044-NA
Item #:N82E16817139044
In Stock
Mail in Rebate Card
$199.99 $199.99
1
AMD A10-5800K Trinity 3.8GHz (4.2GHz Turbo) Socket FM2 100W Quad-Core Desktop APU (CPU + GPU) with DirectX 11 Graphic AMD ...
Model #:AD580KWOHJBOX
Item #:N82E16819113280
Return Policy:CPU Replacement Only Return Policy
In Stock
$129.99 $129.99
1
Mushkin Enhanced Chronos MKNSSDCR240GB 2.5" 240GB SATA III MLC Internal Solid State Drive (SSD)
Model #:MKNSSDCR240GB
Item #:N82E16820226237
Return Policy:Limited Replacement Only Return Policy
In Stock
$199.99 -$30.00 Instant $169.99
1
G.SKILL Trident X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) Desktop Memory Model F3-2400C10D-16GTX
Model #:F3-2400C10D-16GTX
Item #:N82E16820231589
Return Policy:Memory Standard Return Policy
In Stock
$149.99 $149.99
1
Seagate Barracuda 7200.14 ST3000DM001 3TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Model #:ST3000DM001
Item #:N82E16822148844
In Stock
$134.99 $134.99
1
ZALMAN CNPS9900 D/F 140mm & 120mm Long Life Bearing Dual Fans Ultra Quiet CPU Cooler
Model #:CNPS9900 D/F
Item #:N82E16835118138
In Stock
Mail in Rebate Card
Sorry about the formatting, working from a tablet and its making writing a pain.
bacfrombasicbuild
In Stock
$99.99 $99.99
1
Model #:F2A85-M PRO
In Stock
Mail in Rebate Card
1
In Stock
Mail in Rebate Card
$199.99 $199.99
1
In Stock
$129.99 $129.99
1
In Stock
1
In Stock
$149.99 $149.99
1
Model #:ST3000DM001
In Stock
$134.99 $134.99
1
In Stock
Mail in Rebate Card
