Suggestions on this build
Wathnix
I'm looking to upgrade my current system and will be reusing case, power supply, hard drive, ect.
I am an IT student and want something that can do things like virtualization, Ialso I play moderate video games like COD4
Price is flexible.
Qty. Product Description Savings Total Price
1
HyperX Fury Red Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model HX318C10FRK2/16
Item #:N82E16820104467
Return Policy: Memory Standard Return Policy
$159.99
$139.99
Add HyperX Fury Red Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model HX318C10FRK2/16 to cart
1
GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX + SB950 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
GIGABYTE GA-990FXA-UD3 ATX AMD Motherboard
Item #: N82E16813128514
Return Policy: Standard Return Policy
AMD FX-8350 Black Edition Vishera 8-Core 4.0GHz (4.2GHz Turbo) Socket AM3+ 125W Desktop Processor FD8350FRHKBOX
AMD FX-8350 Black Edition 4.0GHz (4.2GHz Turbo) Socket AM3+ Desktop Processor
Item #: N82E16819113284
Return Policy: CPU Replacement Only Return Policy
-$5.00 Instant
-$44.99 Combo
$10.00 Mail-in Rebate Card
$309.98
$259.99
Add combo to cart
Grand Total: $399.98
I would prolly keep the RAM and go for a G3258 - Z97 mobo - 212 evo combo. Will save yourself some cash, overclock it to 4.0 ghz, add in a 250gb ssd and you'll be golden.
Do yourself a favor and get G.Skill ram, it tends to plug and play better with AMD Fx chips. Also what revision of the UD3 board, do not get the Rev 3.0 board you will have issues.
Just got the parts in and they bench test OK, will do full install this weekend (hopefully). 8 cores of AMD goodness to replace my old Q6600 rig. It served many good years but it's way past time to upgrade.
Kevin007--yes, I have a SSD, they are great :D
Mandrake4565--I went with your advice about the gskill memory, and I checked, it's revision 4.0, thanks for the tips
I like the gskill ripjaw x ram. 1866.
Also a good mobo is the crosshair v formula z it makes over clocking simple and what not. I do like the processor as well. Im about to hook up a h100i water cooler to mine.
It's about time you got rid of that Q6600 :p
I recently updated mobo to the m5a99fx and it was a nice upgrade from my old Crosshair III.
Let me know how you like the AMD FX processor. I'm using a 1100T and considering moving to the FX or scratching it off and going back to the blue team. Time and budget will mostly dictate.
