- Mar 7, 2011
My main issue is with the motherboard/RAM. Having a tough time deciding what DDR3 Corsair rams to pick. The motherboard(s) are DDR3 1666(OC)/1333/1066 and DDR3 2000(O.C.)/1333/1066.
Further questions: Will these parts even fit in this case rr should I upgrade to a larger case?
Will this build play games such as BFBC2/Crysis2 with high graphics?
Thanks in advance.
The build so far:
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm Fan, 1x Rear 120mm Fan, option Fans-2x Side 120mm Fan $59.99
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders $109.99
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive $74.99
CORSAIR XMS 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX8GX3M2A1600C9 $98.99
Or
CORSAIR XMS 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory Model CMX8GX3M2A2000C9 $145.49
Or
CORSAIR XMS3 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 Desktop Memory Model CMX8GX3M2A1333C9 $92.49
ASUS M4A89GTD PRO/USB3 AM3 AMD 890GX HDMI SATA 6Gb/s USB 3.0 ATX AMD Motherboard $149.99 DDR3 2000(O.C.)/1333/1066
Or
GIGABYTE GA-770T-USB3 AM3 AMD 770 USB 3.0 ATX AMD Motherboard $89.99 DDR3 1666(OC)/1333/1066
AMD Phenom II X6 1055T Thuban 2.8GHz Socket AM3 125W Six-Core Desktop Processor HDT55TFBGRBOX $179.99
XFX Black Edition P1-750B-CAG9 750W ATX12V v2.2 / ESP12V v2.91 SLI Ready CrossFire Ready 80 PLUS SILVER Certified Modular Active PFC Power Supply $129.99
HIS H685F1GD Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity $174.49
LINKS:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131631 Motherboard $149.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128431 Motherboard $89.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820145325 Corsair RAM DDR3 2000 $145.49
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820145315 Corsair RAM DDR3 1333 $92.49
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820145324 Corsair RAM DDR3 1600 $106.99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811147153 Computer Case $59.99
Thanks in advance.
The build so far:
Or
Or
Or
LINKS:
