Hello all,
Im kinda stuck with this old pc right now, and i decided to just plug in a grafic card, so i can play some ''newer''games on lowest settings....i found this place by reading an old topic , see link below
This is a link to a post of this website, if the policys dont allow it please dont click then
http://www.overclockers.com/forums/showthread.php?t=692390
someone stated he could use a 2.1x16 pci gfx into his mobo, that according to normal specs only allows 1 x16 pci
Before i mess up by installing a grafics card that makes my pc into a toaster i was hoping if you could guide me in the same way.
Cpu: (atm it got a AMD Semprom 3400+) am waiting for AMD Athlon x2 6000+
Mobo: NVIDIA GeForce 6150 SE and NVIDIA nForce 430
RAM: ddr2 ram 2x2 gig
400wat energy suply
The goal is to just add a grafics card of about 40ish euros
The AMD Radeon™ HD 6450(thats also the card the prev. guy used)
seems to be in my pricing....so to make the story short
Will a AMD Radeon™ HD 6450 fit in my Mobo? or do you have a better suggestion for my pricetag
Please help
400wat energy suply
Please help
