Ack. Did you look at Youtubes and other sources before that? Umm yea, yes. Ack. I never seen one like that. WOW.
Might want to do that.
Xfire is working, good.
Here is my CPU, about the same size of your GPU chip. Look how much I put.
http://www.overclockers.com/annual-water-cooling-cleaning-rebuild-journal/
Scroll down about 1/2 way, look for this. Might want to read the whole thing but your focus is on the paste application.
My old CPU block mount and Thermal Interface Material (TIM) Pictures.
Since your new at this you should apply the paste and mount it all the way and take it apart till you know how to do it right.
You didn't take a pic of the full card etc, make sure your thermal tape if used isn't folded over. A foldover will keep the GPU from making full contact. You have a stripped screw? You tighten them with militarty precision one at a time, one turn each till done?
You might want to look at buying new thermal tape also, it gets old after repeated redo. You'll need to make sure it's the same thickness.
And what junk paste are you using? Might need to read lots of posts and learn about pastes. Just buy some MX-4 and your fine.
Lastly, I see a bunch of the original paste on there from your first attempt.
Your rushing it terribly. It will take me 15 to 30 minutes to clean the old stuff off, maybe more And I been at this a long time. Did you even clean the old paste off? To clean up your stuff I would be at it for a LONG time. Needs to BE SPOTLESS for a new install.
SPOTLESS.
I'm a hardass here and tell it how it is.
