- Apr 5, 2012
- Malaysia, South East Asia.
Hey guys , I seen some people using " Pull " configuration for air cooling , which basically it's exhaust i guess...I was wondering does this method actually works?
Because the ones i seen are usually test bench , since their system is all open up and exposed maybe it could work even the cooling isn't so efficient
But thing is im not very sure is it actually set to " Pull " but his fan is on the other side instead of the RAM side...so if were to be in a case , having it as
" Pull " seems more logical , since your rear exhaust fan will able to help pull the hot air out faster from the fan of the heatsink
Has anyone try it ? I tried Google it , not much luck....there is one guy who did numerous of tests...it's basically the same cooling performance as " Push "
Also , could you actually mount your heatsink vertical instead of horizontal ?
Meaning air is being pull up / push upwards instead. Some said it's based on your mounting of your cooler.
But...the way i look at it , isn't it all same either ways ? Anyone have experience with this ? Currently im using a water cool i couldn't try swapping it and if i were to i had to reapply the thermal paste and clean the CPU....
