Ive been researching all kinds of air cooling solutions, trying to get the best combination of low noise excellent cooling for my new system. There doesnt seem to be a general consensus on the validity of the large side intake fan, so I thought I'd perform a real test, hoping it might help give some insight.
Case is a steel Thermaltake Armor with the stock fans, except the Vantec in the top:
CPU Heatsink is a Thermaltake BigTyphoon that I lapped over the weekend. This was my first attempt at lapping, using a very nice kit from EasyPC:
Pre-polishing, you can see the huge low spot in the middle:
After lapping:
Zalman Aluminum Chipset Cooler:
With 40mm Scythe MiniKaze:
Here's the HR-03 mounted on the X1900XT, note how close it is to the CPU - too close for a standard 25mm thick 92mm fan:
For load testing, I ran Prime95 Torture Test, the ATI Tool 'Rotating 3D Cube', and a full system scan with AVG AntiVirus. I was trying to build up in-case temps as high as possible.
Idle Temps:
Stock Side Panel w/o 250mm Fan:
Side Panel w/250mm Blower:
Load Temps (Apps run until temps leveled off, about 30min)
Look at the temp on the GPU!! Running any passive cooler on that X1900XT is just unrealistic
So there it is, the big fan on the side does make a difference, about -5C which is pretty significant. Having the X1900XT's radiator right next to the CPU adds some heat, about 3C to the CPU temps. After allowing the X1900XT to cool down some, CPU load temps dropped to 40C.
Even during intensive gaming, the GPU doesnt get near that hot. An hour of walking through the woods in Oblivion at 1680x1050 with HDR&AA enabled only brought it up ~75C, better than the stock cooler by 10C, - the ATI Tool test really seems to cook it. Im working on a custom shroud to help pull all that heat out of the case.
Also, the 120mm TT fans that came with the case dont seem to push that much air at all, I plan on upgrading them very soon.
Awake77
- 1 120mm 'Thunderblade' and 1 TT 90mm for rear exhaust.
- 1 90mm Vantec Stealth in the top blowhole
- 1 120mm Thunderblade in the front.
- 250mm blower in the side panel.
After lapping:
Idle Temps:
Awake77
