- Mar 30, 2004
I think I will be building my first computer soon and here's the parts I have right now:
Lian Li Silver Mid-Tower Case, Model "PC-60" -RETAIL
Specifications:
Case Type: ATX MID Tower Case
Color: Silver
Material: Aluminum
Drive Bays: 5.25" x 4/0, 3.5" x 3/5 (external/internal)
Expansion Slots: 7
Front Ports: USB2.0 x 2
Power Supply: N/A
Cooling System: 4 x ball bearing fans
Motherboard Compatibility: ATX & pentium 4 (MAX SIZE: 12"x9.6")
Dimensions: 8" x 17.7" x 19" (WxHxD) more info-> N82E16811112022
$90.00
$90.00
Unincom ROUND, 18-Inch, True ATA133/100/66/33 ( UV GREEN ) IDE Cable, 3-Head, 18 Inches.
For IDE Hard Drives, CD ROM, DVD ROM or CDRW.
With PULL TABs - to be used for disconnecting the cable from devices WITHOUT pulling the wires.
Retail. Please see the images. more info-> N82E16812181068
$3.45
$6.90
DFI nForce2 Ultra 400 Chipset Motherboard for AMD Socket A CPU, Model "NFII ULTRA INFINITY" -RETAIL
Specifications:
Supported CPU: Socket A AMD Athlon XP/Athlon/Duron Processors
Chipset: nForce2 Ultra 400 + MCP-T
FSB: 266/333/400MHz
RAM: 3x DIMM support Dual Channel DDR400/333/266/200 Max 3GB
IDE: 2x UltraDMA 133 up to 4 Devices
Slots: 1x AGP 8X, 5x PCI
Ports: 2xPS2,1xCOM,1xLPT,6xUSB2.0(Rear 4),1xLAN,SPDIF In/Out,Audio Ports
Onboard Audio: Realtek ALC650 6-Channel Codec
Onboard LAN: 10/100Mbps
Onboard SATA/RAID: Silicon Image sil3114, 4x SATA w/ RAID 0/1
Onboard 1394: MCP-T+Agere FW803, 3 Ports
Form Factor: ATX more info-> N82E16813136137
$95.00
$95.00
SAPPHIRE ATI RADEON 9800PRO Video Card, 128MB DDR, 256-bit, DVI/TV-Out, 8X AGP -RETAIL
Specifications:
Chipset/Core Speed: ATI RADEON 9800PRO/380MHz
Memory/Effective Speed: 128MB DDR/680MHz
BUS: AGP 1X/2X/4X/8X
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video Out)+DVI Connector
Support 3D API: DirectX®9, OpenGL®2.0
Cable/Accessories: 2 Cables, VGA via DVI Adapter, Composite via S-Video Adpater, 3 CD, Manual
Max Resolution@32bit Color: 2048X1536@85Hz
Retail Box (See pics for details) more info-> N82E16814102281
$216.00
$216.00
Fortron 350W HiQ Brand P4/AMD Ready Power Supply, Model "ATX350GU" -OEM
Specifications:
Type: ATX
Maximum Power: 350W
PFC: No
Power Good Signal: 100-500ms
Hold-up Time: 10ms min.
Efficiency: Min 65%,Typical 70% (at full load)
Over Voltage Protection: Not specified
Overload Protection: 150% Max
Input Voltage: 115V/230V
Input Frequency Range: 47Hz-63Hz
Input Current: 10A/5A
Output: [email protected]/20A,+5V@32/28.8A,[email protected],+12V@16A,[email protected],+5VSB@2A
MTBF: 100K hours at 25ºC
Approvals: UL, CSA, CB more info-> N82E16817104986
$27.00
$27.00
AMD Mobile Athlon XP 2600+, 266 MHz FSB, 512K L2 Cache Processor - OEM
Specification
Model: AMD Mobile Athlon XP
Core: Barton
Operating Frequency: 2GHz
FSB: 266MHz
Cache: L1/64K+64K; L2/ 512KB
Voltage: 1.45V
Process: 0.13Micron
Socket: Socket A
Multimedia Instruction: MMX, SSE, 3DNOW!, 3DNOW!+
Packaging: OEM(Processor Only) more info-> N82E16819103436
$101.00
$101.00
Mushkin 184 Pin 512MB(256MBx2) DDR PC-3200 Level One Dual Pack - Retail
Specification
Manufacturer: Mushkin
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2-3-2
Support Voltage: 2.5V-2.75V
Bandwidth: 3.2GB/s
Organization: two 32M x 64 -Bit
Warranty: Lifetime more info-> N82E16820146289
$127.00
$127.00
Seagate 80GB 7200RPM IDE Hard Drive, Model ST380011A, OEM
Specifications:
Capacity: 80GB
Average Seek Time: 8.5 ms
Buffer: 2MB
Rotational Speed: 7200 RPM
Interface: IDE Ultra ATA100
Features: 350 Gs non-op shock, 3D Defense System
Manufacturer Warranty: 1 year
Remark: OEM more info-> N82E16822148015
$73.00
$73.00
Lite-On Beige 52X32X52 CD-RW Drive, Model LTR-52327S BEIGE, Retail
Specifications:
Write Speed: 52X CD-R, 32X CD-RW
Read Speed: 52X CD-ROM
Interface: ATAPI / E-IDE
Buffer: 2MB
OS Support: Windows 95/98/NT/ME/XP/2000
Features: Innovated SMART-BURN technology
Remark: Retail box (see pictures for details) more info-> N82E16827106198
$34.00
$34.00
Arctic Silver's NEW Premium High-Density Thermal Compound: Ceramique . 2.5-gram( ~0.8 cc. ) tube.
Specifications:
Thermal Conductance: >200,000W/m2.°C (0.001 inch layer)
Thermal Resistance: <0.007°C-in2/Watt (0.001 inch layer)
Average Particle Size: <0.38 microns <0.000015 inch ( 67 particles lined up in a row equal 1/1000th of an inch. )
Extended Temperature Limits: Peak: –150°C to >180°C Long-Term: –150°C to 125°C
Coverage Area: 2.5-gram syringes. (About 1cc) At a layer 0.003" thick, one tube will cover approximately 20 square inches more info-> N82E16835100009
$4.39
$4.39
Thermaltake SILENT BOOST Highest Performance Cooler for AMD AthlonXP up to 3400+ -RETAIL
Specification:
Compatibility: AthlonXP up to 3400+
Dimensions: Fan: 80 x 80 x 25 mm, Heatsink: 82 x 70 x 49 mm
Bearing Type: Ball Bearing
Nominal Speed(RPM): 2450
Max Air Flow: (CFM): 27.5
Max Pressure: 25.97 Pa-min
Heat Sink Material: All copper base, more surface area provides better heat transfer
Rated Voltage: 12V DC
Noise(dBA): 21 more info-> N82E16835106037
$31.99
$31.99
Subtotal »
$ 806.28
If you have any reccomendations, please feel free to post them! Thanks!
-Nico Ritschel
Specifications:
Color: Silver
Material: Aluminum
Expansion Slots: 7
Power Supply: N/A
$90.00
$90.00
$3.45
$6.90
Specifications:
FSB: 266/333/400MHz
$95.00
$95.00
Specifications:
$216.00
$216.00
Specifications:
Type: ATX
Maximum Power: 350W
PFC: No
$27.00
$27.00
Specification
Core: Barton
FSB: 266MHz
Voltage: 1.45V
Process: 0.13Micron
Socket: Socket A
$101.00
$101.00
Specification
Cas Latency: 2-3-2
Bandwidth: 3.2GB/s
$127.00
$127.00
Specifications:
Capacity: 80GB
Buffer: 2MB
$73.00
$73.00
Specifications:
Buffer: 2MB
$34.00
$34.00
Specifications:
$4.39
$4.39
Specification:
$31.99
$31.99
Subtotal »
$ 806.28
-Nico Ritschel
