Installation Instructions (x86-based personal computers)
3) Boot from the CD image
When booting off the CDROM, the first screen you'll see is a
bootloader prompt. You should not need to enter any flags to the
bootloader, so either press enter to continue, or wait 10 seconds
and the boot process will continue automatically.
4) Select the disk to install onto.
After the boot process continues, you will see diagnostic
output from the kernel, and you will end up at an installation
prompt. The installation prompt will list the devices it found
to potentially install Darwin/x86 onto:
The following devices are available for installation:
1. [ Vendor String ] @ /dev/disk0 (size)
2. [ Vendor String ] @ /dev/disk1 (size)
Which device would you like to install Darwin onto?
Enter the number (on the far left) of the device you'd like
to install Darwin/x86 on.
At this point you can also enter the word "shell" to enter
an emergency shell. This should not be needed for normal
installation.
5) Select the partition to install onto.
After entering the disk you wish to install Darwin/x86 onto,
the install script will give you the following prompt:
1) Auto-partition the disk (Destroys all disk contents)
2) Manually partition the disk using fdisk
Choice:
If your disk is already partitioned, you will get a third option:
3) Use existing partitions
The first option (Auto-partition) will destroy the contents of
the disk and create a single Apple HFS+ (journaled) filesystem partition.
This is the preferred option.
The second option (Manually partition) will run the Darwin/x86
fdisk utility. Use this only if you know which partition scheme
you want. This option can also destroy all contents of the
selected disk. If you choose this option, you must create an
Apple HFS+ (journaled) partition of type 0xAF.
The third option will let you install Darwin/x86 onto an already
existing partition. Make sure you already have the partitions
from option 2 set up. The install script will ask you which
partition you would like to use for your root partition.
All contents of that partition will be destroyed.
6) Wait.
The installer will copy Darwin/x86 packages onto the destination partition.
7) Setup.
After installation, you will be prompted to enter a root password.
You will also be prompted to enter a name for the computer (for Bonjour).
8) Reboot.
When the install script is finished, it will give you the choice
of rebooting or spawning a shell. Unless you have post-install
things you wish to do, such as adding additional accounts, you
should reboot the system and remove the install CD from the CDROM drive.
8) Login.
After reboot your machine should be running Darwin, log in and enjoy!
Major Changes Since Darwin 7.0.1
* PowerPC 64-bit support.
* Darwin/x86 installs onto and boots from an HFS+ (journaled) partition.
* GCC-4.0
* Enhanced dlopen(3) API support.
* Korn shell (ksh) included.
* launchd, a dynamic system management daemon, replaces SystemStarter and init
* And much more ...
Known Issues
PowerPC-based Macintosh computers:
* AirPort wireless cards are detected, but cannot be configured.
x86-based personal computers:
* IDE drives may not work on x86. Try it, if it doesn't work,
it's a known problem.
* Video cards must support VESA 2.0 framebuffer modes on x86.
Try it, if your console looks weird, or doesn't appear, it's a
known problem.
