- Dec 17, 2000
- Portland, OR
EventID 6008 tells us nothing other than the system shut down unexpectedly.
Genie BIOS Setting
CPU Feature
Set VR Current Limit Max: Enabled
Thermal Management Control: Disabled
EIST Function: Disabled
CxE Function: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
***** Logical Processor Setting *****
Intel HT Technology: Enabled
Active Processor Cores: All
DRAM Timing
Channel Interleave Setting: AUTO
Rank Interleave Setting: AUTO
Memory LowGap: 1536M
DRAM Command Rate: AUTO/1N/2N etc
CAS Latency Time (tCL): 7
RAS# to CAS# Delay (tRCD): 7
RAS# Precharge (tRP): 7
Precharge Delay (tRAS): 24
REF to ACT Delay (tRFC): AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Row Cycle Time (tRC): AUTO
Read CAS# Precharge (tRTP): AUTO
Four ACT WIN Time (tFAW): AUTO
Voltage Setting
O.C. Shut Down Free: Enable O.C.S.D.F
CPU VID Control: AUTO
Power Saving: Standard
Super VID: OFF
VCore Auto PSI: Disabled
OCP: 140A
DRAM Bus Voltage: 1.650v
DRAM PWM Switch Frequency: Nominal
DRAM PWM Phase Control: 2 Phase Operation
CPU VTT Special Add: AUTO
CPU VTT Voltage: 1.31v
VTT PWM Switch Frequency: Nominal
VTT PWM Phase Control: 2 Phase Operation
CPU PLL Voltage: 1.80v
IOH/ICH 1.1V Voltage: 1.11v
IOH Analog Voltage: 1.10v
ICH 1.5 Voltage: 1.5v
ICH 1.05V Voltage: 1.05v
DIMM 1/2 DQ/DQSTB Bus VREF: -00.0%
DIMM 3/4 DQ/DQSTB Bus VREF: -00.0%
DIMM 5/6 DQ/DQSTB Bus VREF: -00.0%
DIMM 1/2 ADDR/CMD Bus VREF: -00.0%
DIMM 3/4 ADDR/CMD Bus VREF: -00.0%
DIMM 5/6 ADDR/CMD Bus VREF: -00.0%
CPU Core DQ/DQSTB Bus VREF: -00.0%
CPU QPI Drive Strength: Normal
IOH QPI Drive Strength: Normal
Exit Setup Shut down: Mode 2
O.C. Fail Retry Counter: Enabled
O.C. Fail CMOS Reload: Disabled
PPM Function: Enabled
Turbo Mode Function: Disabled
1 core Max Turbo Ratio: 22x
2 core Max Turbo Ratio: 21x
3 core Max Turbo Ratio: 21x
4 core Max Turbo Ratio: 21x
CPU Non-Turbo Clock Ratio: 20x
* BCLK/UCLK/QPI Controller Settings *
QPI Control Settings: Enabled
QPI Link Fast Mode: Enabled
QPI Frequency: AUTO/4.8GT/s/5.866GT/s/6.4GT/s
CPU Base Clock (BCLK): 133 Mhz
Boot Up CPU Base Clock: AUTO
PCIE Clock: 100 Mhz
DRAM Frequency: 6x/8x/10x/12x/14x/16x Memory multipliers
UnCore Frequency: 2x to 32x Uncore multipliers (optimal to keep Uncore at 2x DRAM Frequency)
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
Genie BIOS Setting
CPU Feature
Set VR Current Limit Max: Disabled
Thermal Management Control: Enabled
EIST Function: Enabled
CxE Function: AUTO
Execute Disable Bit: Enabled
DRAM Timing
CAS Latency Time (tCL): AUTO
RAS# to CAS# Delay (tRCD): AUTO
RAS# Precharge (tRP): AUTO
Precharge Delay (tRAS): AUTO
Voltage Setting
Super VID: OFF
OCP: 140A
DRAM Bus Voltage: 1.560v
CPU VTT Voltage: 1.21v
Turbo Mode Function: Enabled
1 core Max Turbo Ratio: 27x
2 core Max Turbo Ratio: 26x
3 core Max Turbo Ratio: 26x
4 core Max Turbo Ratio: 26x
CPU Non-Turbo Clock Ratio: 25x
QPI Frequency: AUTO
PCIE Clock: 100 Mhz
DRAM Frequency: AUTO
UnCore Frequency: AUTO
In Event Viewer, you should be looking for things under "Error" and "Warning" The items listed in thre will give you more information about what triggered the shutdown.
[quote=Error - Driver detected an internal error in its data structures for ]
- System
- Provider
[ Name] sptd
- EventID 4
[ Qualifiers] 49156
Level 2
Task 0
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2014-08-27T11:51:15.045921200Z
EventRecordID 2626696
Channel System
Computer AJ-PC
Security
- EventData
000000000100000000000000040004C0530000000000000000000000000000000000000000000000
Binary data:
In Words
0000: 00000000 00000001 00000000 C0040004
0010: 00000053 00000000 00000000 00000000
0020: 00000000 00000000
In Bytes
0000: 00 00 00 00 01 00 00 00 ........
0008: 00 00 00 00 04 00 04 C0 .......À
0010: 53 00 00 00 00 00 00 00 S.......
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
[/quote]
[quote= Warning - The driver \Driver\WudfRd failed to load for the device ROOT\WPD\0000]
- System
- Provider
[ Name] Microsoft-Windows-Kernel-PnP
[ Guid] {9C205A39-1250-487D-ABD7-E831C6290539}
EventID 219
Version 0
Level 3
Task 212
Opcode 0
Keywords 0x8000000000000000
- TimeCreated
[ SystemTime] 2014-08-27T11:51:26.202185800Z
EventRecordID 2626710
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 208
Channel System
Computer AJ-PC
- Security
[ UserID] S-1-5-18
- EventData
DriverNameLength 13
DriverName ROOT\WPD\0000
Status 3221226341
FailureNameLength 14
FailureName \Driver\WudfRd
Version 0
[/quote]
[quote=The previous system shutdown at 18:13:36 on 27/08/2014 was unexpected.]
- System
- Provider
[ Name] EventLog
- EventID 6008
[ Qualifiers] 32768
Level 2
Task 0
- TimeCreated
[ SystemTime] 2014-08-27T11:52:49.000000000Z
EventRecordID 2626699
Channel System
Computer AJ-PC
Security
- EventData
18:13:36
27/08/2014
9655
DE07080003001B0012000D002400EC01DE07080003001B0008000D002400EC01600900003C000000010000006009000001000000B00400000100000000000000
Binary data:
In Words
0000: 000807DE 001B0003 000D0012 01EC0024
0010: 000807DE 001B0003 000D0008 01EC0024
0020: 00000960 0000003C 00000001 00000960
0030: 00000001 000004B0 00000001 00000000
In Bytes
0000: DE 07 08 00 03 00 1B 00 Þ.......
0008: 12 00 0D 00 24 00 EC 01 ....$.ì.
0010: DE 07 08 00 03 00 1B 00 Þ.......
0018: 08 00 0D 00 24 00 EC 01 ....$.ì.
0020: 60 09 00 00 3C 00 00 00 `...<...
0028: 01 00 00 00 60 09 00 00 ....`...
0030: 01 00 00 00 B0 04 00 00 ....°...
0038: 01 00 00 00 00 00 00 00 ........
[/quote]
[quote=Error - WLAN Extensibility Module has failed to start.
Module Path: C:\WINDOWS\system32\athExt.dll
Error Code: 126]
- System
- Provider
[ Name] Microsoft-Windows-WLAN-AutoConfig
[ Guid] {9580D7DD-0379-4658-9870-D5BE7D52D6DE}
EventID 10000
Version 0
Level 2
Task 0
Opcode 0
Keywords 0x4000000000000000
- TimeCreated
[ SystemTime] 2014-08-27T11:52:50.894575200Z
EventRecordID 2626724
Correlation
- Execution
[ ProcessID] 1440
[ ThreadID] 1872
Channel System
Computer AJ-PC
- Security
[ UserID] S-1-5-18
- EventData
ExtensibleModulePath C:\WINDOWS\system32\athExt.dll
ErrorCode 126
[/quote]
[quote= Error - Faulting application name: nvvsvc.exe, version: 8.17.12.7533, time stamp: 0x4dd742d4
Faulting module name: nvvsvc.exe, version: 8.17.12.7533, time stamp: 0x4dd742d4
Exception code: 0xc0000005
Fault offset: 0x000000000004e437
Faulting process ID: 0x4d8
Faulting application start time: 0x01cfc1ed6ce20656
Faulting application path: C:\Windows\system32\nvvsvc.exe
Faulting module path: C:\Windows\system32\nvvsvc.exe
Report ID: afb7d7e9-2de0-11e4-bf5b-000129223d66
Faulting package full name:
Faulting package-relative application ID: ]
- System
- Provider
[ Name] Application Error
- EventID 1000
[ Qualifiers] 0
Level 2
Task 100
- TimeCreated
[ SystemTime] 2014-08-27T11:52:58.000000000Z
EventRecordID 130617
Channel Application
Computer AJ-PC
Security
- EventData
nvvsvc.exe
8.17.12.7533
4dd742d4
nvvsvc.exe
8.17.12.7533
4dd742d4
c0000005
000000000004e437
4d8
01cfc1ed6ce20656
[/quote]
[quote= Error - The NVIDIA Display Driver Service service terminated unexpectedly. It has done this 1 time(s).]
- System
- Provider
[ Name] Service Control Manager
[ Guid] {555908d1-a6d7-4695-8e1e-26931d2012f4}
[ EventSourceName] Service Control Manager
- EventID 7034
[ Qualifiers] 49152
Version 0
Level 2
Task 0
Opcode 0
Keywords 0x8080000000000000
- TimeCreated
[ SystemTime] 2014-08-27T11:52:59.569290400Z
EventRecordID 2626726
Correlation
- Execution
[ ProcessID] 284
[ ThreadID] 4132
Channel System
Computer AJ-PC
Security
- EventData
param1 NVIDIA Display Driver Service
param2 1
6E0076007300760063000000
Binary data:
In Words
0000: 0076006E 00760073 00000063
In Bytes
0000: 6E 00 76 00 73 00 76 00 n.v.s.v.
0008: 63 00 00 00 c...
[/quote]
[quote= Error - - System
- Provider
- EventID 7034
[ Qualifiers] 49152
Version 0
Level 2
Task 0
Opcode 0
- TimeCreated
Correlation
- Execution
[ ProcessID] 284
[ ThreadID] 4132
Channel System
Computer AJ-PC
Security
- EventData
param2 1
Binary data:
In Words
In Bytes
- System
- Provider
[ Name] SamsungAllShareV2.0
- EventID 0
[ Qualifiers] 0
Level 2
Task 0
- TimeCreated
[ SystemTime] 2014-08-27T11:55:02.000000000Z
EventRecordID 130637
Channel Application
Computer AJ-PC
Security
- EventData
Service cannot be started. System.NullReferenceException: Object reference not set to an instance of an object. at AllShareDmsUtil.Configuration.ConfigurationManager.GetSharingFolderList() at AllShareDmsUtil.Manager.AllShareDmsManager.LoadSharingFolderList() at AllShareDmsUtil.Manager.AllShareDmsManager.InitContentsDirectoryManager() at AllShareDmsUtil.Manager.AllShareDmsManager.Initialize() at AllShareDmsUtil.Manager.AllShareDmsManager..ctor() at AllShareDmsUtil.Manager.AllShareDmsManager.get_Instance() at AllShareDMS.AllShareDMS.DoStart() at AllShareDMS.AllShareDMS.OnStart(String[] args) at System.ServiceProcess.ServiceBase.ServiceQueuedMainCallback(Object state)
[/quote]
Download Driver Fusion, http://treexy.com/products/driver-fusion and clean out the old drivers. No wonder why you are having problems.
You only want it to remove drivers. Don't let it check for outdated drivers. Just use the free version.
That error may be for a usb driver, possibly for a smart phone. Do you have a Samsung phone pluuged into your usb drive?
Load the *.dmp (minidump) files in BlueScreenView...
http://www.nirsoft.net/utils/blue_screen_view.html
Error - The driver \Driver\WudfRd failed to load for the device ROOT\WPD\0000. said:- System
- Provider
EventID 219
Version 0
Level 3
Task 212
Opcode 0
- TimeCreated
[ SystemTime] 2014-08-27T17:17:57.014958400Z
EventRecordID 2626876
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 224
Channel System
Computer AJ-PC
- Security
[ UserID] S-1-5-18
- EventData
DriverNameLength 13
Status 3221226341
Version 0
