- Dec 27, 2008
Got my PII 960T a few days ago and just finished my overclock. I'm very impressed with this CPU! There just can't be a CPU out there with a better performance to price ratio. This is the second build I've done with the Zosma and I'm even more impressed than I was after the first one. The first one was for my daughter and I managed to get it to 4.0 ghz on five cores with an old TRUE cooler and an ASRock 870 Extreme 3 motherboard. Core #5 was defective so I disabled it.
This time around I got one with six viable cores and on just under 1.5 vcore it's Prime95 stable at 3.8 ghz with estimated core temps in the mid 30s C. range. I say estimated because when you unlock cores, as most of you know, you lose the core temp read and have to rely on CPU temp. I did check the differential between core temp and CPU temp before unlocking the cores. The differential was 22 C. and since idle core temps were sub ambient I added 10 C. to the core temp as an offset. CPU temps under load maxed out at 57 C. so I did the math and subtracted about 10 C. from that number to get the core temp estimate. That's where I got mid 30s C. for the core temp and it may be a conservative number. This is on air cooling with a Corsair A70 push pull and fans on low speed.
CPU settings: 19x/1.48 vcore 6 cores
FSB: 200 mhz
CPUNB: 2600 mhz/1.225v
HT Link: 2200 mhz/stock voltage
Ram: running at 1600 mhz using the recommended XMP timings on 1.55v
In case you're wondering, as a four core I got it to 4.1 ghz on just under 1.5 max vcore with temps about 5-6 C. cooler than as a six core at the 3.8 ghz frequency I spoke of above.
I am reasonably certain I could have squeezed a little more out of it both as a four core and a six core if I had been willing to push the vcore envelope more. But my motherboard is not a top drawer enthusiast product (board sinks were starting to get a little warm) and I intend to run this thing 24/7 with these frequencies and voltages so I'm playing it more conservatively than some people might. All information in my sig is current if you care to reference it.
My observations about this CPU:
1. Runs quite cool and the frequency scales quite well with the vcore when overclocking. I didn't get the sense of hitting the wall suddenly like you do with many CPUs that give you a certain amount of overclock with modest voltage increases but only give that one more increment of speed with a lot more voltage. With the Zosma, the wall seems to come at you gradually. I attribute that to the E0 stepping and this being a mature product.
2. Sold as a four core at a quad price but will almost always unlock one core and often times give you two viable unlocked cores.
Get one while they're still being produced!
FSB: 200 mhz
