- Feb 18, 2002
With good power supply, cooling etc.
T-Bred A averages 2.0 GHz or 2400+
T-Bred B averages 2.3 GHz or 2900+
Sometimes more, sometimes a little less but it helps you see where you would be in relation to average overclocks.
I wouldn't go above 1.80 volts Vcore. Read the mobo manual to see where in bios you would increase CPU voltage.
2.0 GHz is about 180 FSB x 11.
Your RAM and mobo limitations are 180ish FSB.
If you're asking for a guess, expect at the most 18x FSB where x is 0 to 9.
Don't screw around with retail cooling and read the link on how to appply thermal paste carefully if you get a better heatsink. (Thermalrights are the best.)
